Introduction
If your 2016 Nissan Altima key fob isn't having a quick response as before, or isn't working whatsoever, use this guide to replace the battery.
They key fob means everything to your Nissan Altima; a key fob with no battery will not allow you to enter nor start the vehicle.
Step 3 requires you to remove the battery from device. Make sure to not touch any component inside with your hands.
Ce dont vous avez besoin
Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
