Aller au contenu principal
2016 Toyota Camry Key Fob Battery Replacement
Ce dont vous avez besoin
  1. 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: étape 1, image 1 de 3 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: étape 1, image 2 de 3 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: étape 1, image 3 de 3
    • Take a coin and wedge it between both halves of the key fob where the keychain notch is. Push against the indent until the fob begins to lift open.
    • Take care not to lose the buttons, as they may fall out.
  2. 2016 Toyota Camry Key Fob Battery Replacement: étape 2, image 1 de 3 2016 Toyota Camry Key Fob Battery Replacement: étape 2, image 2 de 3 2016 Toyota Camry Key Fob Battery Replacement: étape 2, image 3 de 3
    • Look for the notch where it says “use coin to open." Push against the indent with your coin to separate the pieces.
    • Remove the middle console.
  3. 2016 Toyota Camry Key Fob Battery Replacement: étape 3, image 1 de 2 2016 Toyota Camry Key Fob Battery Replacement: étape 3, image 2 de 2
    • Use your fingernail to pry around the battery until it pops out.
    • When inserting the new battery, make sure that the positive side is facing up.
Andrea Esparza
Membre depuis le 03/06/22
115 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Thanks and nicely done. The small plastic clips that hold the battery can be tricky.
Michael Lynn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 119
30 derniers jours : 489
Total : 10,036
