Aller au contenu principal
2017 Chevrolet Traverse Cabin Air Filter Replacement
Ce dont vous avez besoin
  1. 2017 Chevrolet Traverse Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 2 2017 Chevrolet Traverse Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 2 de 2
    • Open the glove compartment.
  2. 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 2, image 1 de 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 2, image 2 de 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 2, image 3 de 3
    • Using your fingers, twist the two fasteners counterclockwise then pull to remove them.
  3. 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 3, image 1 de 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 3, image 2 de 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 3, image 3 de 3
    • On the right side of the glove box, there is a damper. Pull the damper up and then out.
    • This will allow the glove box to fully extend downward.
    • To avoid damage, secure the glove compartment box with your free hand so that it does not drop when you release the damper.
  4. 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 4, image 1 de 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 4, image 2 de 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 4, image 3 de 3
    • Use both hands to pull down on the plastic cabin air filter cover to remove the it.
  5. 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 5, image 1 de 1
    • Remove the old cabin air filter and properly dispose of it.
  6. 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 6, image 1 de 2 2017 Chevrolet Traverse Cabin Air Filter Replacement: étape 6, image 2 de 2
    • Insert the new cabin air filter into the compartment.
    • Pay special attention to the directions on the cabin air filter. The writing should be facing you and the air-flow arrow should be facing downwards.
Hailey Valencia
Membre depuis le 03/01/23
133 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 82
Total : 339
