Aller au contenu principal
2017 Honda Accord Sedan Tail Light Replacement
Ce dont vous avez besoin
  1. 2017 Honda Accord Sedan Tail Light Replacement, Tail Light Bulb: étape 1, image 1 de 1
    • On the driver's side of the car by the left foot-rest, pull the hood lever to release the car hood.
  2. 2017 Honda Accord Sedan Tail Light Replacement: étape 2, image 1 de 3 2017 Honda Accord Sedan Tail Light Replacement: étape 2, image 2 de 3 2017 Honda Accord Sedan Tail Light Replacement: étape 2, image 3 de 3
    • The battery is located on the right side of the engine bay when looking at it from the front.
    • Using a 10mm socket, disconnect the negative (—) terminal on the battery by loosening the clamp around the terminal.
    • Pull the clamp off the terminal once it is loose enough, and tuck it away to ensure that it does not come into contact with the battery terminal.
    • The negative (—) terminal is the side that has black plastic covering it.
    • Do not touch both battery terminals with tools at the same time as electrocution is possible.
  3. 2017 Honda Accord Sedan Tail Light Replacement: étape 3, image 1 de 1
    • Pull the trunk lever to gain access to the trunk.
    • The trunk lever is located on the floor near the driver's side door.
  4. 2017 Honda Accord Sedan Tail Light Replacement: étape 4, image 1 de 2 2017 Honda Accord Sedan Tail Light Replacement: étape 4, image 2 de 2
    • Use a flathead screwdriver to carefully remove the clips circled in red to get to the reverse light bulb.
    • To replace blinker or brake light bulbs, remove the clips circled in orange as shown in the second picture, on either side of the trunk.
  5. 2017 Honda Accord Sedan Tail Light Replacement: étape 5, image 1 de 3 2017 Honda Accord Sedan Tail Light Replacement: étape 5, image 2 de 3 2017 Honda Accord Sedan Tail Light Replacement: étape 5, image 3 de 3
    • Pull back the covering and determine which bulb needs replacement.
    • Remove it by twisting the connector and pulling the bulb from the connector. (This step shows replacement of the reverse light).
    • The third picture shows the backside of the taillight on the left side of the trunk. To replace the blinker light bulb, twist the connector in the orange circle and replace the bulb.
    • The connector in the yellow circle is the brake light bulb. If this bulb is burnt out, twist the connector from the housing and replace the bulb.
  6. 2017 Honda Accord Sedan Tail Light Replacement: étape 6, image 1 de 1
    • Take the new bulb and carefully replace it by pushing the metal end of the bulb into the connector.
    • It is good practice to wear gloves when handling new bulbs, this is because oil from your skin can damage the bulb when operating at high temperatures.
  7. 2017 Honda Accord Sedan Tail Light Replacement: étape 7, image 1 de 2 2017 Honda Accord Sedan Tail Light Replacement: étape 7, image 2 de 2
    • Use a 10 mm socket wrench to reconnect the negative (—) terminal to the battery.
    • Use a partner to ensure the light replaced is now functional.
Andrea Salazar
Membre depuis le 06/08/22
175 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 47
Total : 1,237
