Aller au contenu principal
2017 Jeep Cherokee Air Filter Replacement
Ce dont vous avez besoin
  1. 2017 Jeep Cherokee Air Filter Replacement, Air Filter: étape 1, image 1 de 2 2017 Jeep Cherokee Air Filter Replacement, Air Filter: étape 1, image 2 de 2
    • Pull thehood release lever on the driver's side, under the dashboard until you hear the hood pop open slightly.
    • The hood release is typically marked with a car icon.
    • Walk to the front of the vehicle and reach under the hood to find the secondary safety latch. Slide or lift this latch to fully release the hood.
    • Carefully lift the hood.
  2. 2017 Jeep Cherokee Air Filter Replacement: étape 2, image 1 de 2 2017 Jeep Cherokee Air Filter Replacement: étape 2, image 2 de 2
    • The engine air filter housing is a rectangular, black plastic box situated near the front left of the engine bay (if you are facing the engine bay).
  3. 2017 Jeep Cherokee Air Filter Replacement: étape 3, image 1 de 3 2017 Jeep Cherokee Air Filter Replacement: étape 3, image 2 de 3 2017 Jeep Cherokee Air Filter Replacement: étape 3, image 3 de 3
    • Ensure the engine has cooled down to avoid the risk of burns.
    • Use a Phillips #2 screwdriver to remove the three 8 mm screws securing the air filter housing cover.
    • There are two screws located at the front of the housing and one at the back.
    • Carefully set each screw aside in a safe spot to prevent them from rolling away or getting lost.
  4. 2017 Jeep Cherokee Air Filter Replacement: étape 4, image 1 de 3 2017 Jeep Cherokee Air Filter Replacement: étape 4, image 2 de 3 2017 Jeep Cherokee Air Filter Replacement: étape 4, image 3 de 3
    • Lift the cover off the air filter housing.
    • Observe how the old air filter sits inside the housing to ensure correct orientation when installing the new filter.
    • Remove the old air filter by lifting it straight out of the housing.
    • Inspect it for excessive dirt and debris to determine the filter's condition.
    • Handle the old filter carefully to avoid dispersing accumulated dirt.
  5. 2017 Jeep Cherokee Air Filter Replacement: étape 5, image 1 de 1
    • Place the new filter into the housing, making sure it is properly oriented.
    • The filter should fit snugly without any gaps around the edges.
    • Double-check the orientation and fit of the new filter to ensure proper airflow.
  6. 2017 Jeep Cherokee Air Filter Replacement: étape 6, image 1 de 3 2017 Jeep Cherokee Air Filter Replacement: étape 6, image 2 de 3 2017 Jeep Cherokee Air Filter Replacement: étape 6, image 3 de 3
    • Place the cover back on the air filter housing.
    • Replace the three 8 mm screws and secure them with the Phillips #2 screwdriver.
    • Ensure all screws are accounted for and tightly fastened to avoid vibrations or unfiltered air entering the engine.
Replacing the air filter in your 2017 Jeep Cherokee is a simple and essential maintenance task that helps ensure optimal engine performance and efficiency. By following the step-by-step guide to unfasten the housing, remove the old filter, and install a new one, you can effectively maintain your vehicle's air intake system.
Joseph Howerton
Membre depuis le 03/05/24
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 7-8, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 7-8, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 19
Total : 50
