Introduction
Learn how to replace the headlight bulbs for a 2018 Dodge Charger. All that is required is to open the hood, locate the headlight compartment and replace an old headlight bulb with brand new ones.
This guide walks through the process for replacing the bulbs on both sides - the process differs between them. Skip to Step 9 for the driver's side bulb.
Note: The tools provided are the exact ones used during the repair. Feel free to explore options. The most important is for the socket to be 5/16 inches and compatible with the ratchet you are using to loosen the screws. Use a head flashlight in case you decide to work during the night.
Before beginning, turn off the car, place it in park, and engage the parking brake.
Ce dont vous avez besoin
Open the hood by pulling the release lever inside the vehicle, located on the driver's side by the parking brake.
Carefully place your hands under the hood, towards the middle of the car.
When you feel the lever, push it to the left using your left hand and slowly push the hood up with your right hand.
If your Charger has or requires a stand, prop it up.
On the passenger side of the car, unscrew the cap covering the headlight compartment.
Remove the cap from the headlight.
Slowly twist the bulb clockwise, and remove it from the compartment.
Unplug the bulb from the adapter.
Lift the lever and carefully detach it.
Align the bulb to the shape of the hole and turn clockwise to safely lock.
Place the cap back on the compartment and tightly seal it.
To access the driver's side lightbulb, you have to remove the air intake from under the hood.
Loosen two bolts using a 1/4 ratchet with a 5/16 inch socket.
Once the screw is loosened, use your hand to continue the process.
Loosen the screw attached to the ring.
Detach the tube from the intake.
Grab the intake with both hands and gently lift upwards.
Place the intake safely on top of the main engine block.
Remove the light bulb by lifting on the small lever.
Connect the new headlight bulb and firmly align the bulb to the compartment.
Place the intake back in its original place.
Align the bottom of the intake to its original spot as seen in the picture.
Place the bolt and ring back on the intake.
Tighten the screw with your hands and finish securing the screw using the 1/4 ratchet and the 5/16 in socket.
Firmly attach the tube to the intake.
Tighten the screw using the 1/4 ratchet with the 5/16 inch socket.
Close the hood of the vehicle.
Power on the vehicle to ensure the new headlight bulbs are successfully working.
Congratulations, you've successfully replaced both lightbulbs!
