Aller au contenu principal
2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement
Ce dont vous avez besoin
  1. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: étape 1, image 1 de 2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: étape 1, image 2 de 2
    • Pop the hood and remove the plastic battery cover.
  2. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 2, image 1 de 1
    • Using a 1/4 inch flex head ratchet and a 1/4 inch shallow 10mm socket, loosen the battery cable tightening nut.
  3. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 3, image 1 de 1
    • Remove the vacuum line from the front of the intake by gently pulling up on the line releasing it from the clamps.
  4. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 4, image 1 de 1
    • Disconnect the MAP sensor.
  5. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 5, image 1 de 2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 5, image 2 de 2
    • Using a 1/4 inch 7mm deep socket and 1/4 inch flex head wrench, loosen the worm clamp on the cold air intercooler pipe.
  6. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 6, image 1 de 2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 6, image 2 de 2
    • Using a 1/4 inch 10mm wobbly socket, 1/4 inch 8 inch extension, and 1/4 inch ratchet, remove all 5 of the cap screws holding the intake to the cylinder head.
  7. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 7, image 1 de 1
    • Remove the intake out of the engine bay by lifting and pulling the intake towards you.
  8. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 8, image 1 de 2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 8, image 2 de 2
    • Unplug both left and right engine ground strap connections.
  9. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 9, image 1 de 1
    • Using a 1/4 inch 8mm deep socket, remove the 8 PCV plate mounting bolts.
  10. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 10, image 1 de 1
    • Remove the PCV plate and the old PCV plate gasket.
  11. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 11, image 1 de 1
    • Wipe down the mounting surface and the inside of the PCV plate with a shop rag.
  12. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 12, image 1 de 1
    • Install the new PCV plate gasket.
  13. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 13, image 1 de 2 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: étape 13, image 2 de 2
    • Reinstall the PCV plate on the side of the engine block.
    • Torque the PCV plate mounting bolts to 89 inch pounds.
4 autres ont terminé cette réparation.
2 commentaires de tutoriel
Can this be the p04DB code that came up on my car??
Angelo - Réponse
Would this fix the code p04DB
Angelo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 78
30 derniers jours : 348
Total : 7,243
