Introduction
In this set of instructions, you'll find easy steps on how to replace the Nissan 370z engine air filter. Car engines require consistent airflow to function efficiently. An engine air filter helps to prevent dust, dirt, pollutants, and other contaminants from entering your car's engine. A dirty air filter can have negative effects on the way your engine operates, such as popping sounds, reduced fuel economy, and the production of excess black smoke from the exhaust. It is important to change your filter regularly to improve the performance of your engine. A common rule of thumb is to change the air filter every 12,000 to 15,000 miles, but varies depending on the conditions in which you most often drive.
The tools you may need are gloves, a mask, and a specific air filter for your car. To prevent the inhalation of polluted air molecules, gloves and a mask need to be worn while handling the dirty air filter.
Ce dont vous avez besoin
