Aller au contenu principal
2019 Toyota Highlander Cabin Air Filter Replacement
  1. 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 2 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 2 de 2
    • Open the glove compartment and take everything out.
  2. 2019 Toyota Highlander Cabin Air Filter Replacement: étape 2, image 1 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 2, image 2 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 2, image 3 de 3
    • Press the tabs on the sides of the glove compartment until they are released.
    • Please press the sides gently to avoid any damage.
  3. 2019 Toyota Highlander Cabin Air Filter Replacement: étape 3, image 1 de 1
    • Once the tabs are released, remove the entire glove compartment.
  4. 2019 Toyota Highlander Cabin Air Filter Replacement: étape 4, image 1 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 4, image 2 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 4, image 3 de 3
    • Open the second cover. Position your finger where the red circle is pointing in the first image, then lower it.
  5. 2019 Toyota Highlander Cabin Air Filter Replacement: étape 5, image 1 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 5, image 2 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 5, image 3 de 3
    • Press the tabs on the side of the third cover. Remove the cover.
    • Do not apply heavy force to prevent damage.
  6. 2019 Toyota Highlander Cabin Air Filter Replacement: étape 6, image 1 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 6, image 2 de 3 2019 Toyota Highlander Cabin Air Filter Replacement: étape 6, image 3 de 3
    • Pull the filter out. If the filter is really dirty, then replace it with a new one. Otherwise, clean the filter and return it to position.
Endraws Estefan
Membre depuis le 01/18/21
160 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G7, O'Regan Winter 2021 Membre de l'équipe York University, Team S2-G7, O'Regan Winter 2021
YORK-O'REGAN-W21S2G7
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 47
30 derniers jours : 221
Total : 4,932
