Aller au contenu principal
2021 Chevrolet Silverado Tail Light Replacement
Ce dont vous avez besoin
  1. 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: étape 1, image 1 de 3 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: étape 1, image 2 de 3 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: étape 1, image 3 de 3
    • Open the tailgate.
    • Remove the top and bottom T15 screws from each side of the tail lights.
    • Gently remove the tail lights by pulling outward.
  2. 2021 Chevrolet Silverado Tail Light Replacement: étape 2, image 1 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 2, image 2 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 2, image 3 de 3
    • Unplug the sockets and remove the reverse light bulb from the tail light.
  3. 2021 Chevrolet Silverado Tail Light Replacement: étape 3, image 1 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 3, image 2 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 3, image 3 de 3
    • Plug the brake lights connector.
    • Twist and secure the socket tightly.
    • Plug in the turn signal bulb connector. Twist and secure tightly.
  4. 2021 Chevrolet Silverado Tail Light Replacement: étape 4, image 1 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 4, image 2 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 4, image 3 de 3
    • Plug in the parking lights connector. Twist and secure the socket tightly.
    • Plug in the TURN SIGNALS connector. Please follow the same steps for the other side of the tail lights.
    • Make sure all the connections are plugged and tight. Also ensure that the caps are sealed.
  5. 2021 Chevrolet Silverado Tail Light Replacement: étape 5, image 1 de 2 2021 Chevrolet Silverado Tail Light Replacement: étape 5, image 2 de 2
    • First, remove the reverse light bulb from the vehicle.
    • Then, connect the socket to the reverse light connector from the new tail light.
  6. 2021 Chevrolet Silverado Tail Light Replacement: étape 6, image 1 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 6, image 2 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 6, image 3 de 3
    • Lastly, plug the vehicle’s tail light socket to new tail light connector.
  7. 2021 Chevrolet Silverado Tail Light Replacement: étape 7, image 1 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 7, image 2 de 3 2021 Chevrolet Silverado Tail Light Replacement: étape 7, image 3 de 3
    • Gently push the tail light into the mounting position and use T15 screwdriver to tighten the top and bottom screws.
    • Repeat the same process for the other side of the tail light.
Adrian
Membre depuis le 06/27/23
169 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 53
30 derniers jours : 163
Total : 1,246
