Aller au contenu principal
2021 Toyota Venza Key Fob Battery Replacement
Ce dont vous avez besoin
  1. 2021 Toyota Venza Key Fob Battery Replacement, Key Fob Battery: étape 1, image 1 de 2 2021 Toyota Venza Key Fob Battery Replacement, Key Fob Battery: étape 1, image 2 de 2
    • Flip the fob so the backside is facing up.
  2. 2021 Toyota Venza Key Fob Battery Replacement: étape 2, image 1 de 3 2021 Toyota Venza Key Fob Battery Replacement: étape 2, image 2 de 3 2021 Toyota Venza Key Fob Battery Replacement: étape 2, image 3 de 3
    • Slide the lock to the right.
    • Pull the key out from the top of fob case.
  3. 2021 Toyota Venza Key Fob Battery Replacement: étape 3, image 1 de 2 2021 Toyota Venza Key Fob Battery Replacement: étape 3, image 2 de 2
    • Insert the tip of the key or a spudger into the space where the key was and begin to pry the two parts of the fob apart.
  4. 2021 Toyota Venza Key Fob Battery Replacement: étape 4, image 1 de 3 2021 Toyota Venza Key Fob Battery Replacement: étape 4, image 2 de 3 2021 Toyota Venza Key Fob Battery Replacement: étape 4, image 3 de 3
    • If that doesn't work twist the key slightly and open up the plastic case.
  5. 2021 Toyota Venza Key Fob Battery Replacement: étape 5, image 1 de 2 2021 Toyota Venza Key Fob Battery Replacement: étape 5, image 2 de 2
    • Gently remove the old battery.
  6. 2021 Toyota Venza Key Fob Battery Replacement: étape 6, image 1 de 2 2021 Toyota Venza Key Fob Battery Replacement: étape 6, image 2 de 2
    • Insert a new CR2450 lithium cell battery.
  7. 2021 Toyota Venza Key Fob Battery Replacement: étape 7, image 1 de 2 2021 Toyota Venza Key Fob Battery Replacement: étape 7, image 2 de 2
    • Replace the back case.
    • Press the two halves together and snap it shut.
  8. 2021 Toyota Venza Key Fob Battery Replacement: étape 8, image 1 de 3 2021 Toyota Venza Key Fob Battery Replacement: étape 8, image 2 de 3 2021 Toyota Venza Key Fob Battery Replacement: étape 8, image 3 de 3
    • Insert the key back into the case.
    • You're done!
Press on the controller, and if a red light is shown when pressed, battery replacement is a success.
To double-check, go to your Toyota Venza and press the unlock or lock button; if the car responds, the battery works perfectly fine.
MGaliciaDiaz
Membre depuis le 03/05/24
157 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 7-5, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 7-5, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G5
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 31
30 derniers jours : 76
Total : 138
