Aller au contenu principal
2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement
Ce dont vous avez besoin
  1. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 1
    • Open the glove compartment in the passenger seat area.
    • The cabin air filter is located behind the glove compartment.
  2. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 2, image 1 de 2 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 2, image 2 de 2
    • Carefully detach the support bar from the glove compartment.
  3. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 3, image 1 de 2 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 3, image 2 de 2
    • On the side on the glove compartment there is a sign to push inward.
    • Use both hands to push inward to release the plastic holders on both sides.
    • Carefully lower the glove compartment down.
  4. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 4, image 1 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 4, image 2 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 4, image 3 de 3
    • You will have access to the filter compartment and cover.
    • Pinch the right side of the filter cover and pull toward you; it should come out with ease.
    • Be aware of the signs on the cover when replacing it in Steps 7-9.
  5. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 5, image 1 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 5, image 2 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 5, image 3 de 3
    • Pull the compartment completely out.
  6. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 6, image 1 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 6, image 2 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 6, image 3 de 3
    • Pull out the old filter from the compartment.
  7. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 7, image 1 de 2 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 7, image 2 de 2
    • Grab your new filter and place it into the compartment.
    • On the side of the filter, there are signs of the direction the filter should be placed in the direction of airflow. If placed incorrectly, your A/C will not filter the air well.
    • Pinch to adjust the filter in the compartment.
  8. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 8, image 1 de 2 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 8, image 2 de 2
    • Insert the compartment back into the filter compartment.
    • Make sure you put the compartment upwards in the direction the arrow is pointing.
  9. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 9, image 1 de 2 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 9, image 2 de 2
    • Place the cover back on the filter compartment.
    • Follow the arrow to appropriately place the cover in place.
  10. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 10, image 1 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 10, image 2 de 3 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 10, image 3 de 3
    • Do not forget to attach the support bar back to the glove compartment.
    • You can close the glove compartment. The plastic holders should click back to place.
  11. 2023 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: étape 11, image 1 de 1
    • You have finally replaced the cabin air filter!
By the end of this guide you have successfully replaced the cabin air filter on a 2023 RAV4 XLE Hybrid. Enjoy your clean air!
2 autres ont terminé cette réparation.
Bryan Huinac
Membre depuis le 01/24/23
247 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 17-17, Briggs Spring 2023 Membre de l'équipe CSU Los Angeles, Team 17-17, Briggs Spring 2023
CSULA-BRIGGS-S23S17G17
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 36
30 derniers jours : 193
Total : 1,205
