Aller au contenu principal
3DO FZ-1 Disassembly Guide
Ce dont vous avez besoin
  1. 3DO FZ-1 Disassembly Guide, Lets Begin!: étape 1, image 1 de 3 3DO FZ-1 Disassembly Guide, Lets Begin!: étape 1, image 2 de 3 3DO FZ-1 Disassembly Guide, Lets Begin!: étape 1, image 3 de 3
    • Here we have the front view of the FZ-1 3DO.
    • Note the ports on the back of the unit. The FZ-1 comes with RF, S-Video, and Composite Outputs, as well as a expansion port on the back of the unit.
    • A larger 2nd expansion slot can be found on the right side of the unit.
  2. 3DO FZ-1 Disassembly Guide, Outer Casing: étape 2, image 1 de 1
    • Flip the unit over, so that the bottom side of the case is facing up towards you, exposing the four screws casing screws.
    • Remove the four #2 Phillips Screws from the casing.
    • After the screws are removed, flip the unit back over while holding the top and bottom pieces of the case together.
  3. 3DO FZ-1 Disassembly Guide, Top Casing: étape 3, image 1 de 1
    • Remove the top portion of the case to expose the internal components.
  4. 3DO FZ-1 Disassembly Guide, Disc Drive: étape 4, image 1 de 3 3DO FZ-1 Disassembly Guide, Disc Drive: étape 4, image 2 de 3 3DO FZ-1 Disassembly Guide, Disc Drive: étape 4, image 3 de 3
    • Remove the 2 #1 Phillips Screws from the back of the Disc Drive Shield.
    • Using a Spudger, carefully pry up the four metal tabs to remove the disc drive cover.
    • Remove the 4 #2 Phillips Screws.
    • Remove the disc drive shield, and the two bars you just unscrewed.
  5. 3DO FZ-1 Disassembly Guide: étape 5, image 1 de 1
    • Remove the 5 #1 Phillips Screws holding the CD Drive to the motherboard.
    • Carefully unplug the two ribbon cables connecting the CD drive to the motherboard.
    • You can now safely remove the CD drive from the case.
  6. 3DO FZ-1 Disassembly Guide: étape 6, image 1 de 2 3DO FZ-1 Disassembly Guide: étape 6, image 2 de 2
    • Remove the 11 #1 Phillips Screws connecting the metal shield to the motherboard.
    • Remove the metal shield.
    • Remove the metal cover from the expansion port.
  7. 3DO FZ-1 Disassembly Guide: étape 7, image 1 de 1
    • Remove the #1 Phillips Screw from back port cover, and then remove the cover.
  8. 3DO FZ-1 Disassembly Guide: étape 8, image 1 de 2 3DO FZ-1 Disassembly Guide: étape 8, image 2 de 2
    • Remove the plastic cover, power and eject buttons found at the front end of the unit.
  9. 3DO FZ-1 Disassembly Guide: étape 9, image 1 de 2 3DO FZ-1 Disassembly Guide: étape 9, image 2 de 2
    • Unplug the power and fan cables from the motherboard.
    • Remove the 2 #2 Phillips Screws holding the power supply to the case.
    • The electric screwdriver comes in handy loosening the PSU screws on the FZ-1.
    • Remove the power supply and fan from the case.
  10. 3DO FZ-1 Disassembly Guide: étape 10, image 1 de 1
    • Unplug the ribbon cable connecting the motherboard to the controller port board.
    • Remove the controller board and motherboard.
    • Remove the metal shield at the bottom of the case. Mission complete!
6 autres ont terminé cette réparation.
Ben Eccles
Membre depuis le 02/06/16
873 Réputation
1 tutoriel rédigé
Équipe
Ninja Electronics Membre de l'équipe Ninja Electronics
Business
2 membres
2 tutoriels rédigés
2 commentaires
Can you tell me what size the screws are? I need to order a replacement set for my FZ-1
Richard Poll - Réponse
I thought I couldn't fix this old appliance in my house. Until I came across this site! Thank you. :)
Jellyna Studio - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 28
30 derniers jours : 118
Total : 6,781
