Aller au contenu principal
Outils
Pièces
Aucune pièce spécifiée.
  1. With the back plate off, remove the three  4mm screws using the Hex 2 mm screwdriver. These secure the top plate to the drone assembly. With the back plate off, remove the three  4mm screws using the Hex 2 mm screwdriver. These secure the top plate to the drone assembly. With the back plate off, remove the three  4mm screws using the Hex 2 mm screwdriver. These secure the top plate to the drone assembly.
    • With the back plate off, remove the three 4mm screws using the Hex 2 mm screwdriver. These secure the top plate to the drone assembly.
  2. Rotate the drone 180 degrees (top facing up) and remove the top plate from the drone. Exercise caution as there are wires and components attached to the underside of the top plate!
    • Rotate the drone 180 degrees (top facing up) and remove the top plate from the drone.
    • Exercise caution as there are wires and components attached to the underside of the top plate!
Duncan Applegarth
Membre depuis le 10/02/2020
277 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S7-G5, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 61
