Aller au contenu principal
4-Stroke Small Gas Engine Spark Plug Replacement
Ce dont vous avez besoin
  1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: étape 1, image 1 de 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: étape 1, image 2 de 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: étape 1, image 3 de 3
    • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
  2. 4-Stroke Small Gas Engine Spark Plug Replacement: étape 2, image 1 de 2 4-Stroke Small Gas Engine Spark Plug Replacement: étape 2, image 2 de 2
    • Make sure the engine is turned off and cool to the touch before completing this step.
    • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
  3. 4-Stroke Small Gas Engine Spark Plug Replacement: étape 3, image 1 de 3 4-Stroke Small Gas Engine Spark Plug Replacement: étape 3, image 2 de 3 4-Stroke Small Gas Engine Spark Plug Replacement: étape 3, image 3 de 3
    • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
    • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
    • Remove the Champion RC12YC Spark Plug from the device.
2 autres ont terminé cette réparation.
Jack Linchey
Membre depuis le 04/19/18
277 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 9
30 derniers jours : 17
Total : 1,389
