Aller au contenu principal
4Sight 9 Digitizer Replacement
Ce dont vous avez besoin
  1. 4Sight 9 Digitizer Replacement, Cover: étape 1, image 1 de 2 4Sight 9 Digitizer Replacement, Cover: étape 1, image 2 de 2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Digitizer Replacement: étape 2, image 1 de 1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Digitizer Replacement: étape 3, image 1 de 2 4Sight 9 Digitizer Replacement: étape 3, image 2 de 2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Digitizer Replacement, Motherboard: étape 4, image 1 de 1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Digitizer Replacement: étape 5, image 1 de 2 4Sight 9 Digitizer Replacement: étape 5, image 2 de 2
    • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
    • Put pressure on the connector until the clasp comes undone.
    • Gently pull up on electrical ribbon until it disconnects from circuit board.
  6. 4Sight 9 Digitizer Replacement: étape 6, image 1 de 2 4Sight 9 Digitizer Replacement: étape 6, image 2 de 2
    • Remove the second electrical ribbon from the motherboard.
    • Use the technique for the previous ribbon.
  7. 4Sight 9 Digitizer Replacement: étape 7, image 1 de 1
    • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
  8. 4Sight 9 Digitizer Replacement: étape 8, image 1 de 2 4Sight 9 Digitizer Replacement: étape 8, image 2 de 2
    • With fingers, grip the green Wi-Fi connector.
    • Gently pull up on connector to remove tape holding the connector in place.
  9. 4Sight 9 Digitizer Replacement: étape 9, image 1 de 1
    • Using your fingers, gently lift the motherboard.
  10. 4Sight 9 Digitizer Replacement, Digitizer: étape 10, image 1 de 3 4Sight 9 Digitizer Replacement, Digitizer: étape 10, image 2 de 3 4Sight 9 Digitizer Replacement, Digitizer: étape 10, image 3 de 3
    • Insert plastic prying tool under screen and exert pressure, pulling upward.
    • Repeat this strep around each corner of screen until it pops off.
  11. 4Sight 9 Digitizer Replacement: étape 11, image 1 de 1
    • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes.
  12. 4Sight 9 Digitizer Replacement: étape 12, image 1 de 1
    • Use fingers to gently pull digitizer off of device.
4 autres ont terminé cette réparation.
Hali Ramirez
Membre depuis le 04/07/15
628 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 1,130
