Aller au contenu principal
8BitDo NES30 Pro Gamepad Button Replacement
Ce dont vous avez besoin
  1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: étape 1, image 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement, Button: étape 1, image 2 de 2
    • Hold the controller with its back facing towards you.
    • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
  2. 8BitDo NES30 Pro Gamepad Button Replacement: étape 2, image 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement: étape 2, image 2 de 2
    • Place the controller face down on a solid surface.
    • Remove the seven screws with the Phillips #00 screwdriver.
  3. 8BitDo NES30 Pro Gamepad Button Replacement: étape 3, image 1 de 1
    • Lift the body of the controller up and away from the controller's face and buttons.
  4. 8BitDo NES30 Pro Gamepad Button Replacement: étape 4, image 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement: étape 4, image 2 de 2
    • Lift away the black rubber pads that sit between the face buttons and body of the controller.
  5. 8BitDo NES30 Pro Gamepad Button Replacement: étape 5, image 1 de 1
    • Lift the buttons out of the face of the controller.
  6. 8BitDo NES30 Pro Gamepad Button Replacement: étape 6, image 1 de 2 8BitDo NES30 Pro Gamepad Button Replacement: étape 6, image 2 de 2
    • Align the notches of the face buttons to put them back into place.
    • Each button has a unique notch pattern so it can't be replaced incorrectly.
    • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
2 autres ont terminé cette réparation.
Daniel Kane
Membre depuis le 03/18/21
187 Réputation
1 tutoriel rédigé
4 commentaires de tutoriel
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
Ben Kakita - Réponse
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - Réponse
I wrote 8BitDo support, and explained the issue. They sent me some pads for the price of postage, but only for the buttons -- they didn't send any for the d-pad, which I feel is probably an error on their part.
Izaak Xavier - Réponse
The screws in the N30 Pro are #6 Torx now
Matt Baker - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 62
Total : 2,663
