Aller au contenu principal
8BitDo SN30 Pro+ Controller Triggers Replacement
Ce dont vous avez besoin
  1. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: étape 1, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: étape 1, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: étape 1, image 3 de 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: étape 2, image 1 de 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: étape 2, image 2 de 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: étape 3, image 1 de 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: étape 4, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: étape 4, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: étape 4, image 3 de 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Covers: étape 5, image 1 de 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: étape 6, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: étape 6, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: étape 6, image 3 de 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: étape 7, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: étape 7, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: étape 7, image 3 de 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: étape 8, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: étape 8, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: étape 8, image 3 de 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
  9. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: étape 9, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: étape 9, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: étape 9, image 3 de 3
    • Release the three clips holding the trigger assembly to the main board.
    • Repeat with the other side.
  10. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: étape 10, image 1 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: étape 10, image 2 de 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: étape 10, image 3 de 3
    • Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
    • Gently pry the each side of the trigger out of the round clips.
    • Both conductive pads are now accessible.
Brian W
Membre depuis le 12/21/11
1 773 Réputation
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 61
Total : 4,194
