Aller au contenu principal
AARP RealPad MA7BX2 Back Cover Replacement
Ce dont vous avez besoin
  1. AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: étape 1, image 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: étape 1, image 2 de 2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Back Cover Replacement: étape 2, image 1 de 1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Back Cover Replacement: étape 3, image 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement: étape 3, image 2 de 2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Back Cover Replacement: étape 4, image 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement: étape 4, image 2 de 2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Back Cover Replacement: étape 5, image 1 de 2 AARP RealPad MA7BX2 Back Cover Replacement: étape 5, image 2 de 2
    • Lift off the black audio cover.
Alana Escue
Membre depuis le 09/18/18
425 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 802
