Aller au contenu principal
ACER Aspire V5-571P-6609 RAM Replacement
Ce dont vous avez besoin
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: étape 1, image 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: étape 1, image 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: étape 1, image 3 de 3
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: étape 2, image 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 2, image 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 2, image 3 de 3
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: étape 3, image 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 3, image 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 3, image 3 de 3
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: étape 4, image 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 4, image 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 4, image 3 de 3
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: étape 5, image 1 de 2 ACER Aspire V5-571P-6609 RAM Replacement: étape 5, image 2 de 2
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: étape 6, image 1 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 6, image 2 de 3 ACER Aspire V5-571P-6609 RAM Replacement: étape 6, image 3 de 3
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
Membre depuis le 10/25/22
277 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2022 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 192
