Aller au contenu principal
ACER Aspire V5-571P-6609 Touchpad Replacement
Ce dont vous avez besoin
  1. ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: étape 1, image 1 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: étape 1, image 2 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: étape 1, image 3 de 3
    • Close the laptop and flip over. Locate battery slide release. This guide marks the location with a red circle.
    • Use a pointed tool (we used a screwdriver) to slide release to the right when facing the laptop from the non-battery side.
    • Gently pull the battery away from the laptop with the slide release held open.
  2. ACER Aspire V5-571P-6609 Touchpad Replacement: étape 2, image 1 de 1
    • Remove the two Phillips #0 screws.
    • Once all necessary screws are removed, turn the laptop over and open it.
  3. ACER Aspire V5-571P-6609 Touchpad Replacement: étape 3, image 1 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 3, image 2 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 3, image 3 de 3
    • Slide a Jimmy tool between the top of the keyboard and the outer panel, then gently pop the top tabs out of place.
    • Carefully detach the two flex cables before fully lifting keyboard out in order to avoid cable damage.
    • Once cables are safely detached, lift the keyboard off of the laptop and place it on a safe, non-static surface.
  4. ACER Aspire V5-571P-6609 Touchpad Replacement: étape 4, image 1 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 4, image 2 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the six Phillips #0 screws.
    • Flip up the plastic lock bar mechanism securing the two ribbon cables.
    • Gently pull the cables out of their ports with tweezers.
  5. ACER Aspire V5-571P-6609 Touchpad Replacement: étape 5, image 1 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 5, image 2 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 5, image 3 de 3
    • Slide a Jimmy in between the front and back panel of the laptop
    • Slowly rotate the Jimmy tool in hand until the top panel pops loose. Repeat on all sides until the top panel is free of the main body.
    • Gently lift the top panel free of the main body.
  6. ACER Aspire V5-571P-6609 Touchpad Replacement: étape 6, image 1 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 6, image 2 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 6, image 3 de 3
    • Flip the top panel over and locate the touchpad.
    • Flip up the connector's lock bar from the touchpad, then disconnect the cable.
    • Peel down the adhesive tape securing the touchpad and remove the three Phillips #0 screws securing the touchpad.
  7. ACER Aspire V5-571P-6609 Touchpad Replacement: étape 7, image 1 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 7, image 2 de 3 ACER Aspire V5-571P-6609 Touchpad Replacement: étape 7, image 3 de 3
    • Once screws have been removed, place fingers under and over the touchpad and slowly push it up; firmly hold the touchpad as it is being removed.
    • Replace the touch pad with a new touchpad.
Ernesto Pacheco
Membre depuis le 10/25/22
277 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2022 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 183
