Aller au contenu principal
AKASO KingPad A90 Camera (Rear and Front) Unit Replacement
Ce dont vous avez besoin
  1. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: étape 1, image 1 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: étape 1, image 2 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: étape 1, image 3 de 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 2, image 1 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 2, image 2 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Locate the camera unit and note where it is attached to the motherboard.
    • Grasp the camera unit with tweezers or fingers, and pull firmly to remove it from the adhesive holding it to the motherboard.
    • Be careful when lifting up the camera unit. Don’t tear the ribbon cable! Ensure that you examine the second picture of this step.
    • Using the spudger, carefully loosen the slot's plastic cover piece holding the ribbon cable in place.
    • Pull the ribbon cable out.
    • Remove the old adhesive with tweezers.
  3. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 3, image 1 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 3, image 2 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 3, image 3 de 3
    • Apply a small square of new adhesive in the same spot as the old adhesive was previously.
    • Gently slide the new camera unit's ribbon cable into the slot.
    • Give the ribbon a firm push to make sure it has made contact.
    • Press the plastic cover piece back in place with the spudger.
    • Firmly press the new camera onto the adhesive, making sure to line it up correctly.
  4. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 4, image 1 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 4, image 2 de 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: étape 4, image 3 de 3
    • Replace the back cover with the new camera unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Miles
Membre depuis le 03/24/15
260 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Membre de l'équipe UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 688
