Aller au contenu principal
AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
Ce dont vous avez besoin
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: étape 1, image 1 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: étape 1, image 2 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: étape 1, image 3 de 3
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: étape 2, image 1 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: étape 2, image 2 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: étape 2, image 3 de 3
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: étape 3, image 1 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: étape 3, image 2 de 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: étape 3, image 3 de 3
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Miles
Membre depuis le 03/24/15
260 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Membre de l'équipe UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 7
Total : 510
