Aller au contenu principal
Introduction
This repair guide will walk you through the steps to removing and replacing the fan of your APS Tech 101629 CD-Drive. Fans are easily replaced and the process for removing this fan is fairly simple.
First the casing, channel switch, and power switch will need to be removed.
  1. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
    • Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. Unscrew the four screws previously covered by the feet. Unscrew the four screws previously covered by the feet.
    • Unscrew the four screws previously covered by the feet.
  3. Flip the device right side up, then gently slide the casing upwards and off the hard drive. Flip the device right side up, then gently slide the casing upwards and off the hard drive.
    • Flip the device right side up, then gently slide the casing upwards and off the hard drive.
  4. Flip device upside down again.
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. Batteries pour ordinateurs portables
    Batteries pour toutes les grandes marques d'ordinateurs portables. Qualité assurée par notre garantie.
    Acheter maintenant
    Acheter maintenant
  6. Rotate so back of device is facing you, then gently pry the back casing away. When back casing is removed, the fan will become loose.
    • Rotate so back of device is facing you, then gently pry the back casing away.
    • When back casing is removed, the fan will become loose.
  7. Find the conjoined ID cable wires that are colored black, orange, and yellow, and disconnect it from the white portion. Make sure to lift the white portion of the connection first.
    • Find the conjoined ID cable wires that are colored black, orange, and yellow, and disconnect it from the white portion.
    • Make sure to lift the white portion of the connection first.
  8. At this point, the fan is loose and can be easily moved but not disconnected. Using the spudger, depress the pressure holders at all four corners of the fan. Take out the fan and its cords, by pulling it outward from its cavity within the device.
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
  9. Depress 2 pressure holds on each side of the power switch. Press out the back of the device.
    • Depress 2 pressure holds on each side of the power switch.
    • Press out the back of the device.
  10. Remove all four 4 connections from the power switch. Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • Remove all four 4 connections from the power switch.
    • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • These are very hard to get off, use patience and wiggling.
  11. Remove temperature guage.
    • Remove temperature guage.
  12. Move the exhaust fan out of the way so you can access its control cord. Use the spudger to depress the hold on the fan cord. Gently pull fan cord from connection and remove fan completely.
    • Move the exhaust fan out of the way so you can access its control cord.
    • Use the spudger to depress the hold on the fan cord.
    • Gently pull fan cord from connection and remove fan completely.
Patrick Meyer
Membre depuis le 10/04/2011
83 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-60, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 555
