Introduction
These steps are very similar to steps for LED replacement. The only difference between these two guides are the solder points. Pay close attention to the pictures to make sure that you will be removing the solder from the correct points.
Pièces
Aucune pièce spécifiée.
Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry this piece from the bottom to get the tab from behind the stainless steel to in front of the steel as shown.
Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
These pictures identify the Push Buttons along with their corresponding solder points through the back of the circuit board.
