Aller au contenu principal
ASUS E210MA-TB.CL464BK Battery Replacement
Ce dont vous avez besoin
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: étape 1, image 1 de 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: étape 1, image 2 de 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: étape 1, image 3 de 3
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: étape 2, image 1 de 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: étape 3, image 1 de 2 ASUS E210MA-TB.CL464BK Battery Replacement: étape 3, image 2 de 2
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: étape 4, image 1 de 2 ASUS E210MA-TB.CL464BK Battery Replacement: étape 4, image 2 de 2
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: étape 5, image 1 de 2 ASUS E210MA-TB.CL464BK Battery Replacement: étape 5, image 2 de 2
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: étape 6, image 1 de 1
    • Lift up and remove the battery.
John Hutchins
Membre depuis le 02/07/23
763 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 73-6, Gonzalez Spring 2023 Membre de l'équipe Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 31
Total : 455
