Introduction
If your laptop is having trouble with identifying external USB devices, you may have to replace the port. After ensuring that it is not a software issue, you can use these steps to remove the USB port board.
Ce dont vous avez besoin
Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
