Aller au contenu principal
  1. Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  2. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  3. Use both index fingers to push both spring tabs inwards towards the center of the laptop. Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
  4. With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you. Pull the battery pack up and away from you to completely free it from its recess in the case. Pull the battery pack up and away from you to completely free it from its recess in the case.
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
2 autre(s) ont terminé cette réparation.
Daniel Rodman
Membre depuis le 20/01/2012
267 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-13, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 2,183
