Aller au contenu principal
Introduction
This guide outlines the removal of the RAM for repair or replacement.
  1. Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  2. Use both index fingers to push both spring tabs inwards towards the center of the laptop. Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
  3. With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you. Pull the battery pack up and away from you to completely free it from its recess in the case. Pull the battery pack up and away from you to completely free it from its recess in the case.
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
  4. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  5. With the battery removed, locate the RAM cover.
    • With the battery removed, locate the RAM cover.
  6. Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free. With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
    • Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free.
    • With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
  7. Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module. In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
    • Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module.
    • In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
    • The RAM module will pop upward at a slight angle when both tabs are detached.
  8. Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil. Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
    • Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil.
    • Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
  9. Remove RAM module entirely for repair or replacement.
    • Remove RAM module entirely for repair or replacement.
Patrick Hallahan
Membre depuis le 29/01/2012
38 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-13, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 2,872
