Aller au contenu principal
ASUS Eee Pad Transformer GPS Antenna Replacement
Ce dont vous avez besoin
  1. ASUS Eee Pad Transformer GPS Antenna Replacement, Back Panel: étape 1, image 1 de 2 ASUS Eee Pad Transformer GPS Antenna Replacement, Back Panel: étape 1, image 2 de 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer GPS Antenna Replacement: étape 2, image 1 de 3 ASUS Eee Pad Transformer GPS Antenna Replacement: étape 2, image 2 de 3 ASUS Eee Pad Transformer GPS Antenna Replacement: étape 2, image 3 de 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer GPS Antenna Replacement: étape 3, image 1 de 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer GPS Antenna Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer GPS Antenna Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer GPS Antenna Replacement: étape 6, image 1 de 2 ASUS Eee Pad Transformer GPS Antenna Replacement: étape 6, image 2 de 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: étape 7, image 1 de 3 ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: étape 7, image 2 de 3 ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: étape 7, image 3 de 3
    • Remove the GPS antenna using the spudger.
  8. ASUS Eee Pad Transformer GPS Antenna Replacement: étape 8, image 1 de 3 ASUS Eee Pad Transformer GPS Antenna Replacement: étape 8, image 2 de 3 ASUS Eee Pad Transformer GPS Antenna Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to disconnect the two wires.
    • Remove the GPS Antenna from the device.
Rillian Dennis
Membre depuis le 11/06/19
202 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G5, Harley Fall 2019 Membre de l'équipe IUPUI, Team S1-G5, Harley Fall 2019
IUPUI-HARLEY-F19S1G5
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 165
