Aller au contenu principal
ASUS Eee Pad Transformer Motherboard Replacement
Ce dont vous avez besoin
  1. ASUS Eee Pad Transformer Motherboard  Replacement, Back Panel: étape 1, image 1 de 2 ASUS Eee Pad Transformer Motherboard  Replacement, Back Panel: étape 1, image 2 de 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Motherboard  Replacement: étape 2, image 1 de 3 ASUS Eee Pad Transformer Motherboard  Replacement: étape 2, image 2 de 3 ASUS Eee Pad Transformer Motherboard  Replacement: étape 2, image 3 de 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Motherboard  Replacement: étape 3, image 1 de 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Motherboard  Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Motherboard  Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Motherboard  Replacement: étape 6, image 1 de 2 ASUS Eee Pad Transformer Motherboard  Replacement: étape 6, image 2 de 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Motherboard  Replacement, Remove screws: étape 7, image 1 de 1
    • Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
  8. ASUS Eee Pad Transformer Motherboard  Replacement, Remove metal panel: étape 8, image 1 de 1
    • Metal panel is glued to the battery. Remove with care.
    • Use Plastic Opening Tool to pry off the metal panel from the battery starting on the right side corners and working around the rest of the panel.
  9. ASUS Eee Pad Transformer Motherboard  Replacement, Detach wires: étape 9, image 1 de 1
    • Do NOT pry the battery connector upward as shown in this photo. Instead, pull the connector straight out (in the direction of the wires).
  10. ASUS Eee Pad Transformer Motherboard  Replacement, Remove battery: étape 10, image 1 de 3 ASUS Eee Pad Transformer Motherboard  Replacement, Remove battery: étape 10, image 2 de 3 ASUS Eee Pad Transformer Motherboard  Replacement, Remove battery: étape 10, image 3 de 3
    • Battery is glued to device. Remove with care.
    • Peel off tape from around the edges of the battery.
    • Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
    • Lift up the battery off of the device.
  11. ASUS Eee Pad Transformer Motherboard  Replacement, Motherboard: étape 11, image 1 de 1
    • Use a Phillips #00 Screwdriver to remove the six 3 millimeter screws securing the motherboard to the screen.
  12. ASUS Eee Pad Transformer Motherboard  Replacement: étape 12, image 1 de 2 ASUS Eee Pad Transformer Motherboard  Replacement: étape 12, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Detach the Wifi and GPS antennas (three coaxial cables connected to the motherboard) using hands,metal spudger, or tweezers by lifting away from the device.
  13. ASUS Eee Pad Transformer Motherboard  Replacement: étape 13, image 1 de 2 ASUS Eee Pad Transformer Motherboard  Replacement: étape 13, image 2 de 2
    • Use fingers, plastic opening tool, or metal spudger to lift the clips to the ZIF connector. Remove the ribbon cables attached underneath.
  14. ASUS Eee Pad Transformer Motherboard  Replacement: étape 14, image 1 de 1
    • Remove any tape that is holding down any free wires.
    • Carefully lift the motherboard and slide it out from underneath its constraints.
  15. ASUS Eee Pad Transformer Motherboard  Replacement: étape 15, image 1 de 2 ASUS Eee Pad Transformer Motherboard  Replacement: étape 15, image 2 de 2
    • Unclip the ribbon cable from the ZIF connector using a plastic opening tool or metal spudger.
    • Remove any taped on accessories
Brian Haskell
Membre depuis le 11/01/18
316 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G5, Harley Fall 2018 Membre de l'équipe IUPUI, Team S2-G5, Harley Fall 2018
IUPUI-HARLEY-F18S2G5
3 membres
2 tutoriels rédigés
Un commentaire
i was wondering if i was to purchase a motherboard from ebay that is out of the same model as mine, would their be any issues with the operation after or would oit work like normal..for example, i noticed when i was looking for one online, often times in the description was some kind of id or serial number. i noticed their are stickers on the board itself that seems to correlate with the ones listed in the ads. mine always matched theirs except for the final 3 numbers/letters. if i was to buy one, would their be any issues as far as functionality goes?
Daniel Ogden - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 790
