Aller au contenu principal
ASUS GL752VW-DH74 Keyboard Replacement
Ce dont vous avez besoin
  1. ASUS GL752VW-DH74 Keyboard  Replacement, Optical Drive: étape 1, image 1 de 1
    • Begin by putting the needle into the hole in the disk tray.
  2. ASUS GL752VW-DH74 Keyboard  Replacement: étape 2, image 1 de 1
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Keyboard  Replacement: étape 3, image 1 de 1
    • Pull out disk tray entirely.
  4. ASUS GL752VW-DH74 Keyboard  Replacement, SSD: étape 4, image 1 de 1
    • Unscrew both 8mm phillip's head screws that hold on the access gate.
  5. ASUS GL752VW-DH74 Keyboard  Replacement: étape 5, image 1 de 1
    • Use either the your finger, the screw driver, or a spudger to pop out the gate.
  6. ASUS GL752VW-DH74 Keyboard  Replacement: étape 6, image 1 de 1
    • From here, you can access the hardrive, motherboard, SSD, and RAM.
  7. ASUS GL752VW-DH74 Keyboard  Replacement: étape 7, image 1 de 1
    • Remove the 4mm screw holding in the SSD.
    • Note that the screw is holding it down so it will pop up once the screw is removed.
  8. ASUS GL752VW-DH74 Keyboard  Replacement: étape 8, image 1 de 1
    • Remove SSD from slot.
  9. ASUS GL752VW-DH74 Keyboard  Replacement, Keyboard: étape 9, image 1 de 1
    • Start by unplugging the laptop and turning it upside down. There are 3 screws in the disk drive, remove those using a Phillips #0 screwdriver.
  10. ASUS GL752VW-DH74 Keyboard  Replacement: étape 10, image 1 de 1
    • Remove the medium sized panel attached on the back. Then using your Phillips #0 screwdriver, remove all 8 screws.
  11. ASUS GL752VW-DH74 Keyboard  Replacement: étape 11, image 1 de 1
    • Remove the entire large back panel (outer shell) by removing the screws closer to the outer edge.
  12. ASUS GL752VW-DH74 Keyboard  Replacement: étape 12, image 1 de 3 ASUS GL752VW-DH74 Keyboard  Replacement: étape 12, image 2 de 3 ASUS GL752VW-DH74 Keyboard  Replacement: étape 12, image 3 de 3
    • Use the blue opening tool to gently separate the back panel by loosening it on all sides to ease the outer shell of the laptop until it separates.
  13. ASUS GL752VW-DH74 Keyboard  Replacement: étape 13, image 1 de 1
    • Gently lift the outer shell up until the white, gold and silver power strips are visible. Proceed by removing the strips from the bottom side of the keyboard. Finish removing the outer shell.
  14. ASUS GL752VW-DH74 Keyboard  Replacement: étape 14, image 1 de 1
    • Remove the two Phillips #0 screws located on the panel above the white power strip.
  15. ASUS GL752VW-DH74 Keyboard  Replacement: étape 15, image 1 de 1
    • Gently take off the metal keyboard cover by using the blue opening tool.
  16. ASUS GL752VW-DH74 Keyboard  Replacement: étape 16, image 1 de 2 ASUS GL752VW-DH74 Keyboard  Replacement: étape 16, image 2 de 2
    • Lift up the keyboard panel and replace it with the new one.
5 autres ont terminé cette réparation.
Ryan Maitland
Membre depuis le 10/22/17
188 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G3, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G3
3 membres
5 tutoriels rédigés
3 commentaires
This is an extremely useful tutorial for those who have patience and curious to learn. Excellent job by the authors. Thank you.
Mohan Krishnan - Réponse
This guide needs more work. The metal keyboard has small black pins that keep it in place. They will need to be melted by a heating/soldering gun, and then remelted to keep the new keyboard in place.
gummielindsays - Réponse
This guide is incomplete. You will require a soldering pencil to reattach the new keyboard to its metal backing plate and the laptop faceplate. It could also be useful in releasing the old keyboard from the backing plate and faceplate. if you are slow and cautious it will probably take you 90 to 120 minutes to complete. 40 minutes is only if you have done this type of keyboard before.
Also read the comments regarding the access bay screws that need to be removed during disassembly and remember to remove the sata drive as well.
Kari Hartman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 51
Total : 5,841
