Aller au contenu principal
ASUS K200MA-DS01T Back Panel Removal
Ce dont vous avez besoin
  1. ASUS K200MA-DS01T Back Panel Removal, Back Panel: étape 1, image 1 de 2 ASUS K200MA-DS01T Back Panel Removal, Back Panel: étape 1, image 2 de 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Back Panel Removal: étape 2, image 1 de 2 ASUS K200MA-DS01T Back Panel Removal: étape 2, image 2 de 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Back Panel Removal: étape 3, image 1 de 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Back Panel Removal: étape 4, image 1 de 3 ASUS K200MA-DS01T Back Panel Removal: étape 4, image 2 de 3 ASUS K200MA-DS01T Back Panel Removal: étape 4, image 3 de 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
Haleigh St. Paul
Membre depuis le 09/17/18
239 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Membre de l'équipe CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 10
Total : 193
