Aller au contenu principal
ASUS K200MA-DS01T Battery Replacement
Ce dont vous avez besoin
  1. ASUS K200MA-DS01T Battery Replacement, Back Panel: étape 1, image 1 de 2 ASUS K200MA-DS01T Battery Replacement, Back Panel: étape 1, image 2 de 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Battery Replacement: étape 2, image 1 de 2 ASUS K200MA-DS01T Battery Replacement: étape 2, image 2 de 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Battery Replacement: étape 3, image 1 de 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Battery Replacement: étape 4, image 1 de 3 ASUS K200MA-DS01T Battery Replacement: étape 4, image 2 de 3 ASUS K200MA-DS01T Battery Replacement: étape 4, image 3 de 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Battery Replacement, Keyboard: étape 5, image 1 de 2 ASUS K200MA-DS01T Battery Replacement, Keyboard: étape 5, image 2 de 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Battery Replacement: étape 6, image 1 de 2 ASUS K200MA-DS01T Battery Replacement: étape 6, image 2 de 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Battery Replacement, Battery: étape 7, image 1 de 2 ASUS K200MA-DS01T Battery Replacement, Battery: étape 7, image 2 de 2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Battery Replacement: étape 8, image 1 de 3 ASUS K200MA-DS01T Battery Replacement: étape 8, image 2 de 3 ASUS K200MA-DS01T Battery Replacement: étape 8, image 3 de 3
    • Gripping the wider left section, lift the battery up and away from computer.
Aliyah Malapit
Membre depuis le 09/26/18
199 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Membre de l'équipe CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 299
