Aller au contenu principal
ASUS K53E-BBR1 Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS K53E-BBR1 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 Hard Drive Replacement: étape 3, image 1 de 3 ASUS K53E-BBR1 Hard Drive Replacement: étape 3, image 2 de 3 ASUS K53E-BBR1 Hard Drive Replacement: étape 3, image 3 de 3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Remove the two 4mm Phillips #0 screws on either side of the laptop.
  5. ASUS K53E-BBR1 Hard Drive Replacement: étape 5, image 1 de 2 ASUS K53E-BBR1 Hard Drive Replacement: étape 5, image 2 de 2
    • Slide the back panel towards you until it stops.
    • Lift the panel up out of the laptop casing.
  6. ASUS K53E-BBR1 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the four 3mm Phillips #0 screws holding the hard drive in place.
  7. ASUS K53E-BBR1 Hard Drive Replacement: étape 7, image 1 de 1
    • Disconnect the hard drive from the laptop by sliding it towards the outside edge.
  8. ASUS K53E-BBR1 Hard Drive Replacement: étape 8, image 1 de 2 ASUS K53E-BBR1 Hard Drive Replacement: étape 8, image 2 de 2
    • Grab hold of the black cloth tab and pull the hard drive out from the laptop.
Matthew Merlo
Membre depuis le 03/20/19
267 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Membre de l'équipe UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 266
