Aller au contenu principal
ASUS K53E-BBR1 Keyboard Replacement
Ce dont vous avez besoin
  1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Lift the monitor up so that the keyboard is visible.
    • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
  2. ASUS K53E-BBR1 Keyboard Replacement: étape 2, image 1 de 3 ASUS K53E-BBR1 Keyboard Replacement: étape 2, image 2 de 3 ASUS K53E-BBR1 Keyboard Replacement: étape 2, image 3 de 3
    • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
    • You will hear a light "pop" sound each time you pry the keyboard.
    • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
  3. ASUS K53E-BBR1 Keyboard Replacement: étape 3, image 1 de 1
    • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
Paulo Fortes
Membre depuis le 03/20/19
147 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Membre de l'équipe UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 329
