Aller au contenu principal
ASUS K53E-BBR1 RAM Replacement
Ce dont vous avez besoin
  1. ASUS K53E-BBR1 RAM Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 RAM Replacement: étape 2, image 1 de 1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 RAM Replacement: étape 3, image 1 de 3 ASUS K53E-BBR1 RAM Replacement: étape 3, image 2 de 3 ASUS K53E-BBR1 RAM Replacement: étape 3, image 3 de 3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 RAM Replacement, RAM: étape 4, image 1 de 2 ASUS K53E-BBR1 RAM Replacement, RAM: étape 4, image 2 de 2
    • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
  5. ASUS K53E-BBR1 RAM Replacement: étape 5, image 1 de 2 ASUS K53E-BBR1 RAM Replacement: étape 5, image 2 de 2
    • Slide the back panel backwards until it stops.
    • You can now lift the panel up and out of the laptop casing.
  6. ASUS K53E-BBR1 RAM Replacement: étape 6, image 1 de 3 ASUS K53E-BBR1 RAM Replacement: étape 6, image 2 de 3 ASUS K53E-BBR1 RAM Replacement: étape 6, image 3 de 3
    • The RAM is now visible.
    • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
    • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
  7. ASUS K53E-BBR1 RAM Replacement: étape 7, image 1 de 2 ASUS K53E-BBR1 RAM Replacement: étape 7, image 2 de 2
    • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
    • Gently Pull the RAM out of its connector without pushing down or pulling up.
  8. ASUS K53E-BBR1 RAM Replacement: étape 8, image 1 de 3 ASUS K53E-BBR1 RAM Replacement: étape 8, image 2 de 3 ASUS K53E-BBR1 RAM Replacement: étape 8, image 3 de 3
    • Repeat the previous two steps for the second stick of RAM.
William Colangelo
Membre depuis le 03/25/19
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Membre de l'équipe UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 206
