Aller au contenu principal
ASUS K553MA-DB01TQ Battery Replacement
Ce dont vous avez besoin
  1. ASUS K553MA-DB01TQ Battery Replacement, Keyboard: étape 1, image 1 de 1
    • Turn the laptop over. Using the Phillips Head 000 bit, remove the four 4.8mm screws from the bottom edge. Use the same bit to then remove the remaining six 9.5mm screws.
  2. ASUS K553MA-DB01TQ Battery Replacement: étape 2, image 1 de 1
    • Using the iFixit Opening Tool, pry the keyboard off.
  3. ASUS K553MA-DB01TQ Battery Replacement, Battery: étape 3, image 1 de 1
    • Remove the keyboard from the laptop.
    • Be careful of any ribbon cables attached to the keyboard so you don't rip those out.
  4. ASUS K553MA-DB01TQ Battery Replacement: étape 4, image 1 de 1
    • Using the Phillips #000, remove the four 9.5mm screws around the battery.
  5. ASUS K553MA-DB01TQ Battery Replacement: étape 5, image 1 de 1
    • Carefully disconnect the battery's 8-pin connection to the motherboard.
  6. ASUS K553MA-DB01TQ Battery Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
John Wengierski
Membre depuis le 09/06/19
159 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 227
