Introduction
This guide will show you how to replace the rear camera for a Asus MeMO Pad 7. If you try to take a picture from the rear camera and it is not working at all, this guide will help to replace your rear camera and make it work.
Ce dont vous avez besoin
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
After removing the battery from the device, locate the volume connectors on the side of the device.
Using tweezers, carefully remove the volume connectors and place it to the side.
Flip the motherboard and find the place where the rear camera connector is.
2 autres ont terminé cette réparation.
