Aller au contenu principal
ASUS MeMo Pad FHD10 Headphone Jack Replacement
Ce dont vous avez besoin
  1. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: étape 1, image 1 de 2 ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: étape 1, image 2 de 2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 2, image 1 de 2 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 3, image 1 de 2 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 3, image 2 de 2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 4, image 1 de 3 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 4, image 2 de 3 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 4, image 3 de 3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Speakers: étape 5, image 1 de 1
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 6, image 1 de 1
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 7, image 1 de 3 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 7, image 2 de 3 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 7, image 3 de 3
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Motherboard: étape 8, image 1 de 1
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 9, image 1 de 3 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 9, image 2 de 3 ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 9, image 3 de 3
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 10, image 1 de 1
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: étape 11, image 1 de 2 ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: étape 11, image 2 de 2
    Desoldering Pump
    $3.99
    • Using a soldering gun, desolder the headphone jack from the motherboard at each connection to the motherboard.
    • If you have never used a soldering gun before, check out iFixit's guide for soldering and desoldering.
  12. ASUS MeMo Pad FHD10 Headphone Jack Replacement: étape 12, image 1 de 1
    • Gently, disconnect the headphone jack.
    • Allow the soldering to cool off before disconnecting.
Dmitry
Membre depuis le 01/21/15
391 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 9-5, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,457
