Introduction
This guide will show you how to remove and replace the laptop's CD/DVD Drive. This may be necessary if your drive suffers some sort of hardware failure such as not ejecting or the inability for it to read disks.
Ce dont vous avez besoin
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Remove the two 4mm black Phillips #1 screws from the top of the CD/DVD bracket.
Remove the single 4mm silver Phillips #1 screw from the bottom of the CD/DVD bracket.
Remove the CD/DVD bracket.
2 autres ont terminé cette réparation.
