Aller au contenu principal
ASUS N550JK-DS71T Laptop RAM stick Replacement
Ce dont vous avez besoin
  1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: étape 1, image 1 de 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: étape 1, image 2 de 2
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 2, image 1 de 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 2, image 2 de 2
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: étape 3, image 1 de 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: étape 3, image 2 de 2
    • Remove the three 4mm JIS #0 screws from the battery.
  4. ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 4, image 1 de 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 4, image 2 de 2
    • Using both hands, lift the battery vertically out of the device.
  5. ASUS N550JK-DS71T Laptop RAM stick Replacement, RAM Stick: étape 5, image 1 de 1
    • Put on anti-static wristband and attach clip-end to any metal screw insert.
    • The wristband is recommended when working closely with circuit boards due to potential static discharge.
  6. ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 6, image 1 de 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 6, image 2 de 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: étape 6, image 3 de 3
    • The RAM will be secured by two metal clips surrounded by white plastic.
    • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Steven Hahn
Membre depuis le 01/29/18
875 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 1,141
