Introduction
This guide will show you how to replace the screen on a Asus N550JK-DS71T laptop.
Ce dont vous avez besoin
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Remove the eight black 4mm Phillips #1 screws holding display to laptop base.
After removing the display from the board, slide the grey hinge cap to remove.
WARNING: Do not do it as shown on the picture!
The gray hinge cap should be left in place until you have removed the display assembly. Then you can easily slide it to the side to remove it.
Thx you so much. I cannot plug the grey henge cap beacuse I have broken the some little peaces of the cap. Can I plug that anyway?
I have replaced my screen on this laptop twice, and this piece DOES NOT need to be pried off. It just slides off cleanly when you separate the screen from the rest of the laptop first. I have submitted a proposal to amend this step / have it happen later. Hopefully it gets approved!
Lift the screen from the display to remove.
Using a spudger or soft pry tool, work your way around the edge of the screen to separate the screen from the bezel adhesive strips. Take your time, and be careful not to break the bezel.
Before installing new screen, ensure that the adhesive strips are laying flat around the edges, and clean the surface of the screen of debris from prying the old screen off. These will show up on the new screen if you sandwich them in between the glass and the screen.
8 autres ont terminé cette réparation.
2 commentaires
What is the screen model? I need it to buy a separate controller to use the laptop screen as an external monitor
