Aller au contenu principal
ASUS PadFone X Power and Volume Buttons Replacement
Ce dont vous avez besoin
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: étape 1, image 1 de 1
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: étape 2, image 1 de 1
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: étape 3, image 1 de 1
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: étape 5, image 1 de 1
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: étape 6, image 1 de 1
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
Madeline Dement
Membre depuis le 01/24/17
114 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-1, Baechle Spring 2017 Membre de l'équipe IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 268
