Aller au contenu principal
ASUS PadFone X Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: étape 1, image 1 de 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: étape 1, image 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: étape 2, image 1 de 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: étape 2, image 2 de 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: étape 2, image 3 de 3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: étape 3, image 1 de 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: étape 3, image 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: étape 4, image 1 de 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: étape 5, image 1 de 1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: étape 6, image 1 de 1
    • Once the camera has been pulled out, replace the old camera with a new camera.
nestor
Membre depuis le 10/07/14
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 8-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 521
