Aller au contenu principal
ASUS PadFone X Station Docking Connector Replacement
Ce dont vous avez besoin
  1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: étape 1, image 1 de 2 ASUS PadFone X Station Docking Connector Replacement, Back Cover: étape 1, image 2 de 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Docking Connector Replacement, USB connector: étape 2, image 1 de 2 ASUS PadFone X Station Docking Connector Replacement, USB connector: étape 2, image 2 de 2
    • Locate the CON101
    • The white sticker indicates water exposure. White=none, Red=Exposure
  3. ASUS PadFone X Station Docking Connector Replacement, Remove two Phillips screws: étape 3, image 1 de 1
    • Remove two Phillips screws
  4. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: étape 4, image 1 de 2 ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: étape 4, image 2 de 2
    • Locate P92L on CON1504
    • Gently peel back and remove plastic tape
  5. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: étape 5, image 1 de 3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: étape 5, image 2 de 3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: étape 5, image 3 de 3
    • Gently Pull P92L With Fingers From CON1504
  6. ASUS PadFone X Station Docking Connector Replacement, Identification of Antenna Wires: étape 6, image 1 de 1
    • These are the antenna wires.
    • Trace these wires to locate the two antennas.
  7. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: étape 7, image 1 de 2 ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: étape 7, image 2 de 2
    • Locate the two antennas
    • Desolder the two antenna wires
Daniel
Membre depuis le 10/07/14
338 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 7-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,486
