Aller au contenu principal
ASUS PadFone X Station USB Charging Port Replacement
Ce dont vous avez besoin
  1. ASUS PadFone X Station USB Charging Port Replacement, Back Cover: étape 1, image 1 de 2 ASUS PadFone X Station USB Charging Port Replacement, Back Cover: étape 1, image 2 de 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: étape 2, image 1 de 2 ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: étape 2, image 2 de 2
    • Locate CON2002
    • Check water indicator on USB Charging Port
    • A white indicator means there is no water damage. A red indicator means there was water damage.
  3. ASUS PadFone X Station USB Charging Port Replacement, Removing Charging Port: étape 3, image 1 de 1
    • Locate and remove three Phillips screws
  4. ASUS PadFone X Station USB Charging Port Replacement, Disconnect E893821: étape 4, image 1 de 1
    • Use a pair of tweezers to disconnect E893821
4 autres ont terminé cette réparation.
Daniel
Membre depuis le 10/07/14
338 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 7-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 membres
8 tutoriels rédigés
Un commentaire
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 2,690
