Introduction
Is your device plugged in and still not charging? Have you tried using different chargers and still no luck? Follow this guide to replace the battery inside your device. All you will need are the plastic opening tools.
Ce dont vous avez besoin
Insert the plastic opening tool between the edge of the screen and the back cover.
Gently pry them apart. Use hands to pull them apart if necessary.
Presque terminé !
