Aller au contenu principal
ASUS Padfone X mini Station Front Camera Replacement
Ce dont vous avez besoin
  1. ASUS Padfone X mini Station Front Camera Replacement, Front Camera Lens: étape 1, image 1 de 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Front Camera Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. ASUS Padfone X mini Station Front Camera Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to remove cover sticker on the dock station.
  4. ASUS Padfone X mini Station Front Camera Replacement: étape 4, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. ASUS Padfone X mini Station Front Camera Replacement: étape 5, image 1 de 1
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. ASUS Padfone X mini Station Front Camera Replacement: étape 6, image 1 de 2 ASUS Padfone X mini Station Front Camera Replacement: étape 6, image 2 de 2
    • Use tweezers to detach the camera from the motherboard.
Nuri Syahirah Mohd Safian
Membre depuis le 10/26/18
133 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G7, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Peak Fall 2018
UMASSD-PEAK-F18S2G7
3 membres
4 tutoriels rédigés
Un commentaire
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 192
