Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will be helpful for repairing the speaker if the troubleshooting page recommends that you replace it. This is a necessary step when you have determined no other way to repair your current speaker.
  1. Insert the plastic opening tool between the edge of the screen and the back cover.
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires. Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Disconnect the ribbon from the motherboard by gently pulling with your fingers. Using the opening tools, pry the battery off of the adhesive. Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  5. Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  6. Use tweezers to remove the three pieces of tape that are covering the metal. Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body. Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  7. Use tweezers to detach the connecter from the motherboard. Use tweezers to detach the connecter from the motherboard.
    • Use tweezers to detach the connecter from the motherboard.
Alexzander Pastore
Membre depuis le 26/10/2018
389 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Peak Fall 2018
UMASSD-PEAK-F18S2G7
3 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 93
